Chip or vacuum extractor for router table?
Hsmith192
4 Apr 2020
Kent
Does anybody know if you should use a Chip or vacuum extractor for a router table??
The ports are comparatively tiny, so HPLV extractor is better as it will pull the air through them better.
Hi @Jake & all
I have a similar dilemma to the OP.
The port on the back of my router table fence is 63mm. Not that tiny.
I have two options. I could step down from the 100mm ports on either a HVLP double filtration chip extractor or a HPLV Numatic NVD750 shop vacuum.
Which do you think is preferable and why?
I've read the excellent guide to dust extraction by @siggy_7 but still not sure what the best option is in this scenario. Any advice appreciated!
Cheers!
63mm is tiny for a HVLP extractor. They barely like 100mm, and 63mm is well under half the area/volume. I'd use the Numatic.
Plus to get good extraction you need a wye to the machine port as well, which is invariably even smaller.
Depends what router you have in your table. Are you talking the monsters going up to 1/2” shanked bits, using the large cutters for example regular door making. Or, something more middle sized say like a Bosch POF model, or a trim router in a desktop table. I have the NV750 on my beefier router table. Via a cyclone. My Makita trim router in a desktop table is connected to my wet’n’dry vac.
I have the Bosch GMF1600. Using 1/2” shanked bits including a slot cutter set and a large chamfer bit. From what you and others have said, it seems the NVD750 (with attached cyclone) is the better of the two options.
Cheers.
I used both. I bought one of these and fitted it underneath the table, below a hole cut just beyond the insert plate; I refer to it as The Black Hole because it sucks in everything thrown forward. A 100mm hose runs to the larger extractor and a 63mm comes off the fitting to extract from the dust port on the fence. A small shop vac hose connects directly to the router.
This is the one I have been using, swapped my numeric for it, and it has a larger diameter pipe than the numeric I did get the turbo head from eSpares and what a difference that makes I just plug my power tool into the plug on the vac and as you switch it on the vac starts up, so there’s no messing about with two switches I think they are Swedish, I’ve got there power washer as well about £60 if it breaks at that price I’d just get another but I’ve had it 3 years and it’s still going
    275.1 KB
This is how I made mine. I cut the front off a soil pipe fitting (100mm) and attached it to the fence. There is also a repurposed Scheppach hold down roller. These are great, spring loaded in the vertical plane and by turning the rubber wheel pivot in they also push towards the fence.
Basically a hand powered 'power feed'.
The only 'fault' in my system is that you cannot separate the infeed and outfeed fences.
YwY1VotNichb0L5rew_2X8HDsl1LeYCl1I6YrI7q6RQw9EqfI5Kxh4W4jrw0i45Hy3VmFJ2Y_5tyLb5uY5oadw7FVBjxfqCUsBIm1kSmyCQ7zgwn7NKcUbpNJyHP3vSmRvlLMhRTk7INj_SKdb9nrFK05RucBDPpW92z9Dk6FEVTIvHdGjJGjopGK3-9UHaidW3o8wP2VQVuZU7EJ7oMucZOu6tx4P3Cm2uEqVCX1dvGiJu-FGynCxDObjrp8GoHzWtVf1sEfrWxo21DEtzRNyq5ej43qsfEuDadkMXimQ7Ad0hAp1sFot30c_y7a_D0O_LAHFIU2meeJcJ7OpXxHfHEuDTiTFK-9LXhbUhiSxvldlMGF4r3l8cqZzvQkfan96gYnT3DkdBNnv4lQe4VNqwU37W3ZHszlCP0OuGqt8q51mPDwA-bQ272UZycwmkf4CRuqEVcErri1aqbaZ5J9k57c1BVk7GbmSCBEIYqjXjhipRYyo6_Z0lpMv3M3jbYKDTygbLvQXjfcuLDE6kZan14OSaXyS0-vCLGSMOijAO_VXZc-Zw0OOP2NoLiwMKW16SeYDWS6tu8R4SUsmbF6_EztDZdaerL7k1qfJYcPP4-3WCmoVxTR8yB_5BzQl8VzgJPRgFl8s1-6B-15A-k-yU4DGbr4y7hKIcBs2P4xr48LkBJnTPDCA-bEF3MFGjpD2T4wPLCwiDaNDS80gRkf50=w1235-h695-no
vEGqkTRXUSp3-KWbfe-9VLQ3Ol8ok8q89hCHXNoTwevAGPiBF4ujwd2Nynx7LrZ88JchtuK-mqJhLYMgincjJ0W4VqjFHt4SG8Y1AC6-ckNsxMPPQMwBLm5pE7ZlQfh7X34w0WMZeauRuadHKa9_BkUFkDohfPegzyA4HwlmaNk3J4PxFVObkkjY3Q9Bah78z8lViXlOI9JN7JKEIBQ9e96DNGuWt-mAjT8YfMB9Iya_9XO74VsgcGlHTTeVHvwmpsBEcIKiHkLfTujbwvG_h8a67ITqO6qUoTbv-uBH5YNRVihTxnjQNtmRUgHAABl8j18Eqjm_fWnuS_AnXtuocNVEL3kHj47Avk0TRka9WrhDBuO4Z3cGkKt-UuJ-2-aWcz4BJd8RFu9vvdvUlfe16XzfNB1kCXhP6j9FJehiJIOX9RoJ2fN0aj9dzh0vWZlA7utdxdccSb15ZZr-yrNsTB6g4xYp0etQsTjMAdqHENO0rRMnM1W3LIjQam1Xtp1asQZhfpXcHLsH_rBUPUrxEoZH9Bj1W-CsiPRXu6xtVTLM93f1SncT-WULLXG4RB5MMUR7jH59fNukTQ0zDGGcC-pJPeCluQSIXwEci9F-07rrjEMHiGZChkl3UnWBPcZdDCAruvwZ3iyD18ylXsqTf-r_kveEcnM6fGUsZEa0zQuwdiEd86c0-cYRT5bsKWNNuATsQYuaC8EPx7DwkEOlC5c=w1235-h695-no
