Wizard9999
Just read this from start to finish in one sitting. Superb!
Terry.
Terry.
Really? Perhaps a bit of a myth IMHO.Cheshirechappie":2n4xz36w said:I'm enjoying this one. Really good use of recovered timber.
I'm sure you know this dodge, Andy, but just thought I'd mention that it's worth making the back of the carcase a teensy bit wider than the front - about a bare 1/16" or so. That can make drawer fitting much easier - if by some mischance the carcase ends up wider at the front than the back, there's no way to fit the drawers without a nasty gap between drawer fronts and carcase sides. It seemed timely to mention it now as you're getting to that stage of carcase construction.
Jacob":37cnz2oi said:Really? Perhaps a bit of a myth IMHO.Cheshirechappie":37cnz2oi said:I'm enjoying this one. Really good use of recovered timber.
Doesn't make sense anyway - making it wider at the back isn't going to stop you making it too wide at the front if you are prone that way.
And if you can work to 1/16" accurately you are not likely to make the carcase too wide in the first place. If you can't manage it then it's pot luck - you'd better make all your drawers over-size and fit them one by one.
The way to make sure they fit is to work strictly from a rod with everything on, including your chosen clearance gaps. Then you can even make all your drawers in advance, knowing that they will fit. If you aren't confident about precision you reduce the clearance allowance and expect to have to fit drawers instead of just slotting them in.
Too cunning by half! Cunning ideas sell books (not to mention gadgets) whether or not they are any good.Cunning, them ole boys!
AndyT":3nh57mgu said:then a little planing
Some people would say this was a totally gratuitous excuse to show you this lovely little Preston 1366 bullnose plane; I'd say it was exactly the sort of work it was designed for. :lol:
Owl":pwy6caf0 said:to have it wider at the back etc makes sense to me ..... or have I got it wrong #-o
God he was boring! Had a watch about 3 minutes - I could see no logic at all. In any case it looked a very odd bit of modern furniture.n0legs":2mxuckig said:Owl":2mxuckig said:to have it wider at the back etc makes sense to me ..... or have I got it wrong #-o
Andrew Pitts gives a good description.
From 3 minutes on, simple and clear![]()
https://www.youtube.com/watch?v=VcuTS2TXGg4
Jacob":23xebxya said:God he was boring! Had a watch about 3 minutes - I could see no logic at all. In any case it looked a very odd bit of modern furniture.
Not a good business model. You should know better what the customer wants/needs, and sell them something they didn't even know they wanted. Customer is always wrong is a good starting point.n0legs":woevam3v said:...The customer is always right...
Jacob":10pyqc58 said:Not a good business model. You should know better what the customer wants/needs, and sell them something they didn't even know they wanted. Customer is always wrong is a good starting point.n0legs":10pyqc58 said:...The customer is always right...
