Chess board oil finish??
Thedog
25 Jun 2018
Cornwall
Hello,
From off cuts of a previous project I have made a chess board from Walnut and maple.
I want to apply a good fish to it that will look great without it being too glossy, a nice satin finish perhaps.
I would like to use an oil and not varnish. Something that can be applied easily.
Liberon's finishing oil looks really good. Maybe a few thin coats and the buffed off with some sort of finishing wax.
Any thoughts on this or any advice or suggestions of what would be good?
Also, would it be a good idea to apply a sanding sealer first. I have some acrylic spray sealer and some brush on shellac sealer as well.
Or would this just cause more problems?
Nice project, care to share a picture?
I'm old fashioned, I would stick to linseed oil followed by paste wax. It looks great, is easy to apply, is non toxic, smells nice, and gives a nice satin finish (or some shine if you buff).
I don't think you need sealer, especially not for walnut and maple which are both diffuse porous woods.
Any of the drying oils would work, however some leave more of a colour than others. I prefer tung to linseed, as it causes less yellowing for pale woods like maple. Use a quick drying version though unless you are very patient!
Peri of this parish makes beautiful chess boards look up some of his threads I'm sure he's tried lots of finishes
Hello,
Hello The,
Before the spoon and bowl-making obsession got a hadden of me, just over a year ago, my last piece of proper furniture was a small games table and what will be the first of various gaming boards, a chess/draughts board - in maple & walnut, what else? (With a cherry and black walnut surround, punctuated by black iron nails - gothic, like the rest o' the hoose ornaments).
It's finished in Liberon Finishing Oil - 3 coats rubbed on with a clean and lint-free piece of cotton sheet then buffed when dry with a very soft brush before application of one coat of Liberon neutral wax. This imparts a shine but it's muted by the paste wax to a degree. It's not the toughest finish but unless the chess becomes violent, that shouldnae matter, eh?
    115 KB
    235.8 KB
    200 KB
Thanks to everyone for your replies.
Eshmiel, what paste wax did you use? The Liberon Black Bisson was looks pretty good, not sure if it would be suitable over the finishing oil.
Also, what about a hard was oil as the last coat over a couple coats of Liberon finishing oil, would that work?
I could try a few thing, but it becomes expensive and time consuming.
I've made several chess boards over the years and I'm not looking forward to the next one only because they take so much time and render the bench unusable while being finished. I'll try to keep this brief. I have used ash and black walnut as I think it makes a good contrast. I always run the board through a drum sander (friend of mine has one) as the final bit of the assembly. Clean, and clean again. I then use oil based clear gloss varnish cut 50 / 50 with spirits, as this allows the varnish to flow out. I don't use water based as it dries too quickly. Apply it with a clean lint free cloth going against and with the grain. Wait 24 hours until the next coat, and sand lightly with 800 and spirits before the varnish. Use as many coats until you get the color you want. It usually takes three or four coats. I the use Aqua Coat filler (sort of filler). two, three coats until the board is smooth. Then a number of more coats of the varnish. I saw one board that was gloss on the board and satin on the surround, looked interesting. Have a beer and vow not to make another one, until someone asks you to make one!
