I have aquired a cherry tree stump about a metre and a half. I cut it up and sealed the ends with old gloss paint lying about in the garage. I cut it into manageable sizes. This is a product of a part of the stump.
After drilling a hole through the centre I used a 3/8 bowl gouge to cut it out. Being a complete novice at this i had to develop a technique After trying the cutting edge in different angles I found the best way was at an angle with the gouge and the left side of the flute at approx 10 o'clock.
I coated the outside with sanding sealer three times ans lightly sanded between each coat until I saw the wood starting to glow.
I do hope there will be some comments
