smiley65
just bought a shed and need to insulate it but need to do it on a budget any help would be great
Could you put the breather membrane on the inside Mike and build inwards?MikeG.":23dabz8q said:The answer is that there is no good way of doing it. This is why I strongly advocate people building their own sheds or workshops rather than buying off the shelf ones. The building paper/ breather membrane should go outside the frame, but it can't because there is cladding in the way. There should be a 25mm gap behind the cladding boards, which typically doesn't leave enough room for insulation. If you can only fit 25mm of mineral wool insulation (plus the 25mm air gap) in the depth of the "frame", then it simply isn't worth the trouble of doing. You'll get no benefit from so little insulation. I don't know what to suggest I'm afraid, other than "don't start from here".
