katellwood
Can anyone assist, I am having trouble changing orientations when performing certain actions namely using the circle tool or protractor tool to change axes,
e.g. when drawing a circle it will enable me to draw the circle in the blue axis but will not change to the red or green, I am aware that you can lock the axis by pressing the shift key however i cannot get it to toggle in the first instance
The same problem occurs when I wish to rotate a certain item I click to protractor tool to rotate but cannot toggle between the three axes it just stays on one,
Do I have to live with this or is their an easy fix
