I just measured the power consumption of the original circulation pump that was retained when the GSHP was fitted. It is consuming 85 watts.I fitted a Grunfoss Alpha and it only uses a maximum of 7 watts
I think the end result is probably like any communication network in that it will default to the speed of the slowest device. These pumps are not positive displacement, just circulators and unless they are both trying to move the same flow of water then one must restrict the flow. If both were identical then they must be additive but not sure if this applies to circulators.Is the upstream pump arguing with the downstream one? I can't see that they are simply additive?
Yes, exactly so.So, the ground source heat pump I assume is on 24/7 and controls the house temp with its weather compensator?
Yes. This is an old pump that is in series with another pump that is part of the GSHP. The old pump runs 24/7 and the pump in the GSHP is controlled by the GSHP.The radiator pump runs the central heating water for the radiator and has no controls on it and runs 24/7 I assume this is a leftover from the oil central heating?
When the fault occurs the system does not reset itself, so the fault condition persists until I do something to get things working again.When the fault occurs how long does it last for and how does it right itself?
There are 2 water circuits. One contains water with an antifreeze additive and runs through pipes buried in the field at the back of the house. The other runs through the radiators. Both loops run through the GSHP with no direct connection between the 2 loops. Instead, the GSHP acts like a fridge in reverse, taking energy out of the field loop and putting it into the radiator loop. So a bit more complicated than a simple heat exchanger, but similar in principle I guess.Does the same water run through the ground source heat pump and central heating system or is there a heat exchanger fitted to separate them?
OK, so that knocks my theory on the head.The capacitor in a pump is a run capacitor and is needed for for both start and run.
Ok Just for fun you are really Dick Strawbridge and I claim my £5 . 45 rads must be a chateaux you live in![]()
That seems very likely to me. I can't see how else you can keep the glycol and the radiator water separate with just one pump, unless you have one pump motor with 2 impellers/circulators, (I've never seen one but maybe they exist.) Both need to run to keep the rads warm but they may be doing diferent things.is it possible that one pump is circulating the glycol mixture in the heat pump and the other the water around the heating system
My goodness its the Von Trapp school of music, Nice pile you have thereOK, so that knocks my theory on the head.
No £5 for you I'm afraid, but yes, it is a big old house. Count the windows: most of them have a rad below them.
That gizmo only tell you that the motor shaft is turning. It does not tell you whether the impeller has become detached from the motor shaft.These are handy for testing circulating pumps.
In forty years as a heating engineer never had a Grundfos let go of the impeller. Maybe I was luckyThat gizmo only tell you that the motor shaft is turning. It does not tell you whether the impeller has become detached from the motor shaft.
Had a couple of Grundfos let go but, as you say, the Wilos are known for it.In forty years as a heating engineer never had a Grundfos let go of the impeller. Maybe I was luckymostly happened on Wilo ones.
First couple of Wilos caught me out after that first thing to check was the impellerHad a couple of Grundfos let go but, as you say, the Wilos are known for it.
