SVB
I have decided to have a bit of a roughing out session as I have a garage with loads of logs that will realistically never dry on their own so some progress is needed!
Rather than dumping most of it on the floor, I was considering buying a centre saver. Whilst I like the simplicity etc of the fixed oneway and similar units, something deep down is drawing me to the McNaughton blade system.
Couple of questions therefore - firstly is there a wet / dry timber issue in the selection of these items.
Given they are not cheap (what is?), other than the oneway, woodcut and mcNaughton kit, is there anything else I should look at first. ( I am after shallow rather than deep bowls so I have discounted the sorby arm brace parting tool solution for this reason - does this sound reasonable?)
Logs are typically 12 -14" dia so not massive. Anyone have the McN system - which one is most use, mini, std, or larger for this size blank?
As they say on exam papers - discuss!!!
