segovia
I am in the middle of a bathroom refurbishment. The CH supply pipework is tectite copper pushfit, probably 25 years old or more.
I feel I need to replace them as once the tiled floor is done there is no access
Options are
Tectite lifespan is between 25 and 50 years depending on which site you look at, if I take the lower figure the current are due for replacement.
I am leaning towards pre soldered, I have not done any plumbing for a while so confidence is low with a torch and solder.
What would you go ?
I have a plumber doing the final fit, but the floor will be down by the time they arrive at site
J
Options are
- replace with plastic pushfit
- pre soldered joints
- standard soldered joint
- Leave it as it is
- replace with new tectite
What would you go ?
J
