In an old Popular Woodworking, Adam Cherubini indicated that the "center drill bits" are (in his opinion) the best period bits, especially for hard woods. I acquired a few of these bits and tried out a 3/4" specimen. I sharpened the cutting edge and filed the inside of the outer spur and tried to make a hole in oak. The bit makes a hole, but it is excruciatingly slow. It seems that the problem is the center spur, which doesn't cut. It limits how fast the cutting edge can work. Bearing down as I drill doesn't seem to help. I found that when i drilled a pilot hole for the center spur then the bit cut much faster (like maybe 10 times faster). But the wrong sized pilot hole leads to problems with centering, and a ragged hole. And in any case, surely the best period bits shouldn't require a pilot hole. I tried sharpening the center spur but that didn't seem to make any difference.
So I'm wondering if anybody knows how to make these bits work.
Here's a picture of the type of bit I'm talking about to make sure there's no confusion. (Not my picture.)
