Cellulose Sanding Sealer
Ian
5 Apr 2007
Northern Ireland
Hi
I have been using shellac sanding sealer and was wondering can anyone tell me the benifits of using Cellulose Sanding Sealer.
I have found that shellac can clog the sandpaper if it is old but was wondering if the Cellulose Sanding Sealer is better at not clogging.
cheers
Ian
Cellulose sanding sealer works for me!
I save shellac products for french polishing
Dodge
I always use cellulose sanding sealer as I find the shellac one tends to be soft. Cellulose sanding sealer dries quickly and once fully cured is hard and easy to sand. It does however soften the underlying coats when it is applied if they are also cellulose. :wink:
This is a question we haven't been asked before because normally customers that are french polishing use Shellac Sanding Sealer. In saying that we can't see you experiencing any problems using the Cellulose SS beneath french polish.
Hope this helps
Ian
