Aragorn":uyk9tkn8 said:Woody - that's such a serious budget, you don't need to concern yourself with aluminium or CI... Can you buy machines for £2000+ made from aluminium?
My inclination would be to avoid combination machines where poss if you want to do any kind of "production" work unless the machines are of such high quality that you can guarentee repeatablilty once you've altered the setup (Felder?).
I'd agree with Aragorn on this, can you even get aluminium on tables with a budget that large? Do Felder use aluminium on their sliding table?
I think the budget puts the machines out of a league where I can reasonable comment! Doesn't this put you into the world of Felder and others?
Given that's a serious amount of money, it's likely to be a large (physically and in electrical requirements) machine, possibly ones which are not offered in single-phase options, three phase only, so you'll need either a phase converter, or an electrician. Even if you can find them in single phase, you may need to get an electrician in to wire it up from a dedicated supply, as these are not going to be comparable to the supply requirements of a "normal tablesaw".
One comments on the P/T, With that budget, surely you won't have to make the comprimise that nearly all of us have made, which is either long beds and narrow blades, or shorter beds and wider blades? Twice last week I had to rip down some boards to get them into planer - and my planer is 26cm wide. I can't understand how you guys manage with only 8" planer knifes on your Jet - do you always use super thin stock for tables et al? Anyway, with a big budget it's irrelevent surely, as you get the benefits of both!
A final comment on seperate or joined planer thicknessers, for me, it takes less than 60 seconds to switch over, I simply lift a lever, lift and then lock the hinged table, flip over the extractor port and I'm finished. In my case, as I don't have the luxery of space, I'd have to lift the a seperate thicknesser from a storage space to somewhere to use it, and that'd actually take longer.
Adam
