MikeG.
I'm not really a carver. I own no specialist carving tools, but I own chisels and a couple of gouges. That should be enough, I reckon, to carve a half-reasonable Tudor rose or three in oak for my stairs. Rather than set it out with compass, ruler and pencil directly on a piece of wood, I drew it on the computer and printed it:
Gummed into place with a bit of Pritstick, I then cut through it with chisels so I had all the principle lines, and cut out the shape on the bandsaw. I then rounded over the outside edge, and lowered the five little pointy leaves:
I would have made things a lot esier for myself if the radii of the curves of the design matched the radii of the curves of my gouges. They don't.
If you can chisel, you can carve. It just requires the ability to read the grain. Which direction do I take this cut? Anyhow.......
Here's the first one "clamped" in place with the glue drying. One down, two to go.......
