I got a couple of carbide tools last week from
https://www.ukwoodcraftandcarbidechisels.co.uk/ and have turned a 3 bowls as a learning experience. I got a round one and a square one, pointy one is next I guess.
I'm interested in getting opinions on what to expect from their use. So far this is what I've been doing and my observations, any hints or tips appreciated.
I use square one to make sure the blank is round and balanced, The cutting edge when going in, what I'd consider a plunging action doesn't seem all that great, I mean it does it, but I get much better results from using the corners and sweeping across. I expected the plunging to be a bit more aggressive than it seems to be when pushing in. I also use this for flattening the front and back faces which seems remarkable easy - again, using the side of the blade, not the front. I also use it for squaring up and flattening the interior of bowls.
I use the round one for clearing out most of the interior of the bowls and I get beautiful streamers flying off (I get the same for the square one) . Also use it for generating a little bit of decoration, I prefer using the round one as its roundness seems to help the flow of the tool. I try to get a clean light cut towards the end and it give a nice smoothish finish. If I don't ramp up the speed a bit more then It can mean the surface gets 'bumpy' = turning the speed up and a couple of passes and it's nice and smooth. I saw something the other day about turning the lathe speed up if you're "riding air" - so I gave it a go to see what would happen and results were a lot better.
There are a couple of my tries in
this thread ( I'm not going to post there anymore, clogging up the nice turnings).
