Davey44
Batteries these days aren't cheap, at least not if you're replacing one on a car that has the stop/restart system. Depending on the actual type they can be upwards of £180.00, and in my book that isn't cheap.
Other contributors are right, in that once a car refuses to start it probably isn't any good just replacing the battery unless/until you've checked out all possible problems. For example a boot/hatchback light that doesn't go out when the lid/hatchback is closed. That's proven to be more common than many people think. Answer, lock your wife or the loudest of one of your kids in there and close the lid/hatchback and see what response you get.
Seriously though, when ours has very occasionally refused to start I've left one of the reliable maintenance chargers under the bonnet plugged into a single extension ('throwaround') socket and close the bonnet securely. Given a good 12 hours of charge should be sufficient to get your engine started.
