Can you get a
A mate of mine uses a "Henry" with his scroll saw - much quieter than a normal extractor and easy to empty.
But then in your workshop would look a bit daft against that monster roof lifter!! :lol: :lol: :lol:
Rog
Rog
:mrgreen: :mrgreen: :mrgreen:
Get a little hose, small diameter and a T junction. Hook this up to your tap. Put the water on. Take a the bit of hose from the T and it will suck and water will come out of the other side of the T. It will be queit and relaxing. Should do for the minimal dust a scroll saw makes :)
Humm :-k :-k :-k
running water
I will be in the loo all day :mrgreen:
What about the cost if you are on a water meter! :shock:
I know that water doesn't come out of both sides. The only reason I know this is that when we were about 12 at school they gave us a smoking demonstration, obviously they couldn't light up, smoke it then show us the filter so they instead did this which sucked the cigarette. One of the more interesting science lessons seen as I remember it.
You could always keep the water and pour it back in at the top. :)
There is one of 2 situations here Chems? Either you are not putting this down in a manner that I can comprehend or I am thick as a brick? Probably the latter, but I an intreigued? Is there any way that you can google your 't' piece so as to give a better description? I ain't being alkward 'onest. Just very interested as to how it works #-o #-o #-o
Water doesn't come out of the T because of the Venturi effect. We used to use this type of suction in the lab on aBüchner funnel. Don't expect much suction though and it's dependent on the flow rate of the water. More info: http://en.wikipedia.org/wiki/Venturi_effect.
This same effect is used to remove protein from fish tanks when keeping tropical salt water fish - a large (ish) pump is used though to create a decent pressure differential so that you can introduce tiny bubbles.
A 'T' and a venturie are 2 very different animals WCogs and if a 'T' worked on the same principle as a ventirie tehn I wouldn't get any water in our house because all we would get would be bubbles as the connection is via a 'T' and it goes on then to my workshop.
Thinks? If that is the case, do I have a built in dust extracter? No way... :evil: :evil:
It may have been more elobrate than a T then, but thats how I remember it in my mind. Like I said thou, I was 12 and that was I'm afraid quite a while ago now.
It isn't a 90 degree T, more like 135 or 45 depending on which way you are measuring. The water can't go up the line where suction is created.
suction -------------- water out
water in
Sorry for the poor line drawing - ignore the 2 dotted lines. Spaces seem to get removed.
Dibs
Blister":3kmcramw said:
Silent dust extractor / vacuum
or quiet
I want a dedicated unit to work with a scroll saw
Any recommendations ? :wink:
My Festool is not too noisy for it's type, but still not quiet.
Have you considered building a sound-reducing box to go over an extractor, maybe even putting it outside?
The bit of lab equipment Chems is refering to is a filter pump item 122 on this site http://www.saiscientific.co.in/misc.php
The water doesn't come out the side - honest. According to some of the marketing on the websites it requires 7.5 psi of water pressure to pull 28.5" of mercury
Ok thanks for that
So what pipes are the inlet and outlet ?
Does it require a powerful pump ?
or something like a fish tank pump
I assume you would need to regulate the water flow some how
Has anyone else used this method of dust extraction ?
    2.7 KB
