- Joined
- 6 Jun 2011
- Messages
- 3,007
- Reaction score
- 924
Hi Laurence
I understand your desire to want to reuse your existing UJK lift and have received drawings from a forum member trying to help you re-engineering your lift to suit.
I am very pleased you would like to buy one of my AUKTools routers but want to ensure you end up with the best solution, I would rather lose a sale than over promise and have an unhappy customer. I see several problems, some of which are below.
My AUKTools router weighs almost 5Kgs, and I think its too heavy for the 6mm UJK top plate, we do not sell any router plates or lifts with 6mm thick plates, my fear is it will bend.
I also do not know what weight router the UJK lift is designed to accommodate but the components are not comparable with JessEm or Incra lifts.
Slinging the router under the fixing plate will cut off the airflow out of the router and cause overheating, cutting a larger hole in the UJK mounting plate may weaken it.
Round bodied routers within our Incra and JessEm lifts allow for cutter change above the table, you will lose this feature. You could buy a Muscle Chuck from us to try and over come this issue but our AUK ER20 collects are fantastic! You will just be throwing more money at the lift problem.
I suggest you reconsider your plans, I can not recommend you proceed.
Peter
Peter
