I don't have the workshop or skill required do it, although if someone was watching over me correcting me I could. So could someone build a box for me?
It's for a bicycle trailer, to fit on a Carry Freedom large Y Frame (remove supplied base board) I'm not sure which material and thickness is best, ply? 9mm? I would like it strong but don't want it over engineered to the point it weighs a ton. But don't want 1mm balsa wood either.
Must be local (Staffs, Cheshire area)
I have 8 eye bolts and want these spaced to allow bungee cords to be used.
80cm length, 62cm width, 50cm height. With overlapping lid with lockable clasp.
Fixing points for lights
Dovetail joints.
Rated maximum carrying weight of the Y frame is 90kg.
although if there were ready made templates, should be able to do it...
Got a circular saw, router, router bits, jigsaw, manual planer, drill, wood and metal drill bits.
Dovetail joints.
