Why? Well I bought an aluminium router table plate and cut the hole in my table top for it. All fine up to that point. I've now got a second plate with a different hole configuration that I want to use instead. It's from the same company as the original plate but is clearly a slightly newer model as it now has their logo on It is supposed to be the same size as the first but is a hairs breath wider so won't drop in. It might just be the powder coating I need to take off the edges or may be a bit of metal, so can I just sand it and will I likely make a pigs ear of it?
I think doing this if possible will be less hassle than making a new template to enlarge the hole in the table top. I can't send it back by the way it was bought in the states not cost effective and too long ago now.
Mark
Mark
