There are a few ways you could go about this. The first step is to remove any existing finish. Depending on whether the timber is naturally dark or whether it is stained and how light you want to go will depend on what you do next. You could wipe on neat domestic bleach, allow it to dry and repeat up to another three times. Rinse with fresh water and allow to dry. If the timber is stained your best bet will be to use oxalic acid. Liberon do a ready mixed solution..... Wood Bleacher: Furniture and Interior Woodwork Repair and Prepare | Liberon wood cares you can repeat this application three or four times, rinse with plenty of fresh water and discard your rags making sure no child or pet can come into contact with them. If it does not bleach after three applications it's not going to work. If your timber is a good Caribbean mahogany that is naturally dark your only option is to use A+B bleach.... FIDDES A & B Bleach - FIDDES. Wear marigold gloves and eye protection, apply the A + B with separate rags, rinse the rags after use then dispose of them. You can repeat this application up to but not more than three times but it should work first time. When the timber is bleached to the desired shade rinse with copious amounts of water and leave uncovered for three days before applying any sort of finish.Hey all.
Is there a way of making a darker wood banister lighter in anyway ?
I can’t find much online to help.?
