I'm buying a dust extractor and am caught as to whether it should be the cam-vac, or the axminster.
The axminster is the big dual system, priced at £800, and the Cam-vac is £480
I was initially favouring the Axminster, but now I'm thinking maybe the cam-vac would be the better extractor. Basically its a lot smaller, considerably cheaper and I think pretty much is going to do the same thing.
I need it for mainly the planer/thicknesser, and bandsaw, and of course powertools like sanders and routers.
Its the planer/thicknesser that im more interested in knowing if the cam-vac has the oomph needed.
I think the axminster is ideal if i had a bigger workshop, maybe connected to a system, and the cam-vac would be more suitable really for my smallish workshop and what im actually doing. The Ax one is pretty bloody huge,which is why im thinking the cam-vac would be better given my workspace is only about 120 sq feet, it would take up a fair bit of room.
I'm also intending to buy an air cleaner(record power version) so i think the combined 0.5 micron on the camvac and the 1 micron on the air cleaner should pretty much leave me with a healthy dust free environment.
So does anyone own a cam-vac extractor, namely the 386-5 and do you use it on a planer/thicknesser ?
Capabilities - need explaining if anyone's worked it out.
Axminster extractor is 1400 cubic meters/hour - Which is fine for anything ive got
The cam-vac 108 liters/second
I have no idea how one equates to the other, or even if you can equate it, given the axminster is a HVLP
I also like the fact on the cam-vac you've 2 independently switched motors, so for powertools etc you only need the one switched on.
Any info or review anyone has would be much appreciated.
Got a good testing vid here, the 3 motor cam-vac over the standard chip collector.
Even taking into account the one im thinking of having 2 motors, I think it would still come out on top.
