Did a few jobs on the new tablesaw today., like got the riving knife to drop below the blade although it will be maintained at the correct height most of the time unless those special cuttings are required.
I’m wondering why I needed to do the above as an afterthought because if the blade cover has got tobe removed the riving knife might just as well come out as well? I’m thinking tenons and rebates.
Next to get the fence to read zero I had to remove around 15mm from the front end of the rail, I couldn’t move the bracket on the fence any further over, otherwise I would have had an L bracket and not a T bracket, fence to rail! And the Tape measure is glued on.
Next job was sorting out the ruler reader dial, the red line is useless so I turned the plastic magnifier 90% and used a bit of masking tape to give me the read off on the ruler. ( the piece of timber laying there was to get my camera exposure meter to focus)
Dropped the rear table level down so that wooden guides can slide off the end of table, but in the meantime a temporary ply sheet ( from Axminster packing) brings up level required for ripping.
Made some more rip cuts and I observed the timber slide along the fence for the first part of its travel and then the centre part of the timber being cut came off the fence by around a mil. And then using the push stick and correcting pressure I got it back to the fence for the last portion of the timber.
Finally I got the timber to cut to half a mil. oversize which at the present time is acceptable to me because I always clean up the cut and size on the thicknesser.
Requesting help from those who have made a sled for their tablesaw.
I want to tilt the blade to 45% and run the sled through the blade. Is there any reason why this is a no,no. ?
I know I could also cut my mitre upright upto 3” (75mm) but that is a very deep mitre to get cut accurately.
Looking at the Freud catalogue for a rip blade there does not appear to be anything for 250mm x 30 bore x 27 teeth? The only mention of ripping seemed to be the one Martin purchased but that has 60/80 teeth.
I have got some very heavy dense timbers and I think a ripping blade would be necessary.
