wwwigz
New member
Hi - thi is my first post here, hopefully the first of many!
I hope this is in the right section, are there any UK furniture restoration forums?
I have a narrow drawer unit that was pulled form a much bigger piece and I decided to smarten it up and re-finish it.
I'm not an experienced woodworker but am beginning to learn, hoping to start both joinery and furniture resoration courses in september. I did a little bit of inlay banding with the drawer fronts and cleared the drawer runners.
I sanded the old varnish down, then wiped with a turpentined cloth. After letting it dry for a few days, I then wiped a thin layer of boiled linseed oiled in.
Should I wax it? (I only have Pine Wax)
Should I wipe a layer of varnish onto the already thin wiped in oil?
Can anyone tell what the wood is likely to be? I've attached as many photos with descriptions as I can. The flashed photos give it ore colour and contrast depth than in real life, colours alot more even.
There's a little more inlay trimming and sanding to be done, and maybe some repair work to the foot and the possibility of putting a 'top' on it.
Thanks in advance for any opinions, I've had a search but nothing specific came up.
