petermillard
Anyone know which other suppliers track is the best alternative?
The excel rail is the closest copy of the Makita rail I've ever come across. Excel 1.5m Aluminium Guide Rail for Makita and Festool Plunge Saw.
![đź‘Ť đź‘Ť](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f44d.png)
Never mind the reviews. Do you own a Makita and have you tried doing a scoring cut?From memory, the Makita 'scoring' facility has a niggle, a slight offset relative to main cut. From @Spectric table - not much to choose DeWalt/Makita?
Equally, scoring doesn't seem to score high on any of the reviews?
It also precludes use of Makita rails with the larger Festool TS75, but as that's really a bit of a specialist tool I doubt it will bother many folk...Equally I think the lip in question does prevent the uses of some of the festool track accessories if you ever want to use them...
TBH I haven't used the scoring facility very much, but basically the method I use doesn't tilt the blade, but allows me to make a 2mm deep cut, pulling the saw backwards across the material. Providing you clamp the guide rails to the material this works well. I've used it to make clean cuts on splintery birch plywood with my DSP600 on a good two dozen occasions in the last 6 weeks (for shadow gap cladding on birch ply where a clean edge is essential), so I'm not sure where your "niggle" comes from, although I do tend to be sceptical of reviews in general because it can take some time to learn about any power tool
Let's face it, though a scoring facility won't often figure highly in the list of reasons to buy one of these saws, will it?
You've hit the problem of there being no such thing as a standards between manufacturers, or even within a range (?), I'm afraid. Even with Festool the same problem used to exist with TS55 blades, with some having 2.2mm kerfs, others 2.4mm or 2.5mm.kerfs, etc. So change blades and you'd need to move the anti splinter strips, potentially. Festool sorted that out in the end (by adopting 2.2mm as the standard) but it took several phone calls to Festool (and a fair bit of trial and error adjustment) to fix the issue of the TS75 and the TS55 not tracking the same. When I introduced a DSP600 into the mix I ended up experimenting with paper and plastic shims beneath the blade to get the DSP to track the same as the Festools and a mate made me up a balanced HDPE shim so my saw would work on the Festool tracks (by pushing the blade out about, from memory, 1.5mm but zi wasn"t using the EfiCut blades and still don't as I find them expensive). But that all got undone when the Mak went back to them under warranty (and they removed the shim and presumably chucked it).Today I received delivery of a Makita 36v plunge saw, the DHS680Z. I understand that it will share the Festool tracks, which is why I bought it. I previously used a little Makita 18v handheld and was blown away by the quality of the cut with the Makita 'efficut' blade installed, so I plumped for plunge saw from the Makita range with said blade. Having the second, smaller and lighter weight, plunge saw to share the Festool rails alongside the TS75, was my plan.
In the last few minutes I have opened the Makita Macpac box and plonked the new machine onto a Festool guide rail (track). Problem - the Makita with it's lovely thin-kerf 'efficut' blade installed plunges onto the splinter guard, the offset is different between the two saws. Oh no! I have adjusted the Makita to glide nicely on the rail, to remove play but not so much as to make the saw bind on the rail. I think the difference is about a millimetre, the blade being closer to the guide rail on the Makita.
I bought the TS75 specifically to handle heavy solid wood doors which we were renovating on one job. It has been used for a few other specific tasks (such as ripping down 5 metre long x 60mm thick sapele cappings which were delivered 20mm too wide, etc) but for general use I found it too big and too heavy for prolonged use
You've hit the problem of there being no such thing as a standards between manufacturers, or even within a range (?), I'm afraid. Even with Festool the same problem used to exist with TS55 blades, with some having 2.2mm kerfs, others 2.4mm or 2.5mm.kerfs, etc. So change blades and you'd need to move the anti splinter strips, potentially. Festool sorted that out in the end (by adopting 2.2mm as the standard) but it took several phone calls to Festool (and a fair bit of trial and error adjustment) to fix the issue of the TS75 and the TS55 not tracking the same. When I introduced a DSP600 into the mix I ended up experimenting with paper and plastic shims beneath the blade to get the DSP to track the same as the Festools and a mate made me up a balanced HDPE shim so my saw would work on the Festool tracks (by pushing the blade out about, from memory, 1.5mm). But that all got undone when the Mak went back to them under warranty (and they removed the shim and presumably chucked it).
Sorry to say, but I ended up keeping a couple of rails for the TS75, the TS55 is now "in reserve" whilst the DSP600 has now got four shiny new Makita rails (3 x 1500 plus 1 x 1000mm)
Because the Makita isn't adjustable in the same way you might want to consider some DIY blade shims, or alternatively adjust the TS75 to match the DSP instead (the TS75 base has adjusters)
What rail square ? and for doing repetative cuts you may want to look at parallel guides but at the moment I am content with my Makita track saw but a rail square is on the list.I have ordered a rail square with the intention of fitting it to a Festool rail and using it with an MFT style top for x-cuts, the Makita would work with this set-up, being more handy, so will probably experiment here. Looking forward to it actually!
The Benchdog square is the one I am thinking of, having looked at what is out there it has a good price for the quality and it fits Festool and makita tracks because they are very similar apart from the Makita has those anti tipping lugs for when doing 45° cuts. Benchdogs are going to be selling a repetive stop attachment for it at some point.With your Makita track saw I expect you can get a rail square to fit the Makita rails if you consider it important or when the time comes.
No, pretty sure it’s unique to Mafell; the Makita - like all the others afaik - has a simple depth stop for the scoring cut; only the Mafell has the cutesie blade-shifting trick that didn’t work quite as planned on the one I had.Has anyone experience of this, I did see in a Pete Millard video this was an issue on I believe the Maefell but not seen it on the Makita.
I have noticed this a lot with some of the big stores. I do not know if it is incompetence in not taking down old adverts or putting up a few items for sale and leaving the advert in place with the “Customers who bought this also browsed“ section at the bottom to get visitors to visit their website. I suspect the latter, irritating.Sorry to pee on your fire but I think that you will find that B&Q have advertised that price but out of interest I looked and the item is not available for home delivery and even though I live near to one of the largest B&Q in the country it shows no stock and also no stock in any nearby store.
The Festool doesn’t have a specific “scoring” facility but it is so quick to set the saw to 2mm depth of cut that it doesn’t need it. Usually the scoring cut is made by running the saw backwards down the track. The budget saws aren’t as easy to set to precise depth so it might not be so convenient. By the way, scoring melamine like this works really well.From memory, the Makita 'scoring' facility has a niggle, a slight offset relative to main cut. From @Spectric table - not much to choose DeWalt/Makita?
Good choice sir!
Tool stop have the saw for ÂŁ280 and track for ÂŁ54.
https://www.toolstop.co.uk/makita-sp6000j1-plunge-cut-saw-165mm-240v-p66961/
What sort of price are you after?
In terms of other track, it’ll work with most but you won’t be able to use the anti-tip feature (useful when making bevel cuts) as that’s unique to Makita and their rails have a little lip to accommodate it.
(Equally I think the lip in question does prevent the uses of some of the festool track accessories if you ever want to use them)
Peter Millard has a video about track options
This shows the little knob to set the scoring feature to give a shallow cut, cannot see any mention of offset issues.12.32 into this video.
Look at microjig clamps, not cheapest but anything that can provide multiple uses is more cost effective rtaher than single use. With these clamps and some simple dovetail groves in a worktop you have a very flexable clamping solution as well as holding your tracks.I've been searching for Guide-Rail-Clamps which could be used for Any type of Rail.
