frugal":3ie29z8i said:I am going to ask a stupid question: Apart from being more accurate and having less play in the parts, what is the difference between a milling machine and a pillar drill?
From the photos of the Axminster machine, it looks just like a pillar drill with an adjustable table.
From the top of my head:
- The spindle is fixed, with a pillar drill when rotating the handle the chuck goes down, you need to hold it in the same height, when you let go of the handle the spindle travels back up.. Which a milling machine the head can trafel up and down by means of a wheel and stays at that height even is upward or downward pressure is applied.
- The chuck is fitted to the spindle by means of both a machine taper and a piece of threaded rod (called a draw in bar). So the chuck does not fall out due to the sideward pressure when milling
- The rotation speed range is wider - it can rotate much lower
- The bearings of the spindle act in both up, down and sideward axis, whereas with a pillardrill only act for forces in the upward direction
- The milling head can most often be rotated left and right.
- The castings are heavier to handle the load and reduce vibrations
- The power drive is geared in stead of belted, this provides more transfer power and no slip
- The motor is most often more powerful
In short: a pillar drill is the equally the same as a milling machinel as a plunge router is. They all spin, a bit can be mounted, make noise and a mess.
