chippy1970
Just got myself a ply lining kit for my T5 van but the floor is in two sections split down the centre. Its 9mm WBP pretty good quality but I want to make the join a proper joint. I was thinking of running a 4mm groove with my biscuit cutter and use a long 4mm strip of ply as a loose tongue. Only trouble I see with this is there will only be 2.5mm of ply left either side of the tongue this may be weak I dont know.
When its dry out there I will take a proper look I may have room to just put a ply strap screwed to the under side of the joint.
Any other ideas ????
