Graham Orm
Do you have back to back evidence that a burnisher is better? I use a chrome vanadium screwdriver which seems to work fine.
matthewwh":2o5ug8u2 said:Depends on your screwdriver I suppose.
I've tried screwdrivers, backs of gouges, drill bits... then tried an Arno and the urge to experiment went away.
Grayorm":s3dy5v4k said:Do you have back to back evidence that a burnisher is better? I use a chrome vanadium screwdriver which seems to work fine.
Pete Maddex":18jini9h said:I have tried a Two Cherrys burnisher a hard screwdriver but the best thing I have found is my home made burnisher made from a Carbide milling cutter, its about 3mm in diameter and works very well. I thing the small diameter has a smaller contact patch that increases the force on the scraper.
I made three and gave two away.
The cutter are still for sale if you want to make one.
http://www.ebay.co.uk/itm/310635074873? ... 1423.l2649
Grayorm":2ztcl9wr said:Do you have back to back evidence that a burnisher is better? I use a chrome vanadium screwdriver which seems to work fine.
bugbear":3lmon49s said:Pete Maddex":3lmon49s said:I have tried a Two Cherrys burnisher a hard screwdriver but the best thing I have found is my home made burnisher made from a Carbide milling cutter, its about 3mm in diameter and works very well. I thing the small diameter has a smaller contact patch that increases the force on the scraper.
Did you (need to) polish them any further beyond their delivered state? They're only shanks after all...
BugBear
matthewwh":qv73ritf said:Depends on your screwdriver I suppose.
Grayorm":1snsnu5v said:I use a chrome vanadium screwdriver which seems to work fine.
tobytools":2ayucqt4 said:The Clifton burnished is all your ever need, no messing about with screwdrivers, rods and that. They may work I'm not saying they don't (screwdrivers and the like).
Job done
TT
bugbear":2xpfve7s said:tobytools":2xpfve7s said:The Clifton burnished is all your ever need, no messing about with screwdrivers, rods and that. They may work I'm not saying they don't (screwdrivers and the like).
Job done
TT
I think Mr Maddex's carbide way is (a lot) cheaper, as well as being harder...
That being said, on the scale of things, even a "proper" burnisher is cheap, so if ya' got the dough - buy what you like!
BugBear
bugbear":iumcb4i5 said:tobytools":iumcb4i5 said:The Clifton burnished is all your ever need, no messing about with screwdrivers, rods and that. They may work I'm not saying they don't (screwdrivers and the like).
Job done
TT
BugBear
tobytools":1galozlk said:I really like "The home made tooll who dosent. I've made plenty but when you note how long you have taken to get from raw materials to a finished piece
Say 2hours, and what your worth an hour (go by work pay)
It's cheaper to buy a new one.
CStanford":2n3kd41n said:I have the Clifton and love it. There's no need for carbide. The Cliffy is hard enough -- works fine on a vintage Sandvik scraper, the standard by which others are measured.
