dance
Hi
I'd like to build a bench seat with storage for our kitchen ostensibly out of 'oak'. Because I'll be using oak (£££), and because I can't go and SEE the timber before buying, I wanted to run it by someone if possible?
So I've found SL Hardwoods who seem to have a reasonable range and good pricing compared to many places. Their delivery charges seem reasonable, too.
Basically I think I'm building a box frame out of pine 2x4 (is this overkill? would 2x2 do the job just as well?) and then attaching my oak veneered plywood to this frame...then tacking genuine oak PSE to the oak veneer to give the impression of oak panelling.
In my basket at SL Hardwoods I have:-
Oak Crown Cut Plywood MR Veneered 1 Side Only 9mm 2.4m x 1.2m
Oak American White Planed All Round Board 19mm Thick x 140mm
I've telephoned to check and the American White matches the type of oak used in the veneer. The plan is to rip the 140mm length down the middle to get 65mm wide lengths to use as the panelling.
What do you reckon?
P.S. I am going to model it in sketchup first to check on the amount of oak needed so I'm not really asking "Am I buying enough", more "will this work?" and "Is this a cost effective way of doing it?"
What do you reckon?
