Derek Cohen (Perth Oz)
This was todays work:
http://www.inthewoodshop.com/Furniture/ ... 82%29.html
Regards from Perth
Derek
Regards from Perth
Derek
custard":1s5hvzlg said:Derek, are you absolutely determined to replicate that particular joint? The reason I ask is that it has "spindle moulder with a factory jig" written all over it! I'm sure that somewhere in the design/manufacturing process there was a handmade prototype that would have had a more traditional joint, and I don't think you'd be giving anything up if you followed that route, I'm equally sure that if that prototype ever surfaced at an auction the market would endorse that view with a breathtaking price!
An other option would be to fabricate the jig for a local joinery company with similar tooling to run it through their spindle moulder. The skill for a joint like that is 100% in the jig making rather than the actual cut, so again no disgrace going that route.
One final point (excuse the pun) is that the "pointy fingered" version has a serious problem in that the feather edges are very vulnerable and if they crumble or split off then you've no way of avoiding a gappy glue line. It's virtually certain that there will be some short grain close to the point, which would make a breakage pretty inevitable.
