billw
The Tattooed One
I do realise this is a slippery slope :shock:
...and then some :lol: - Robbillw":3ppnhh28 said:I do realise this is a slippery slope :shock:
billw":34pbfd2l said:I'll show my newbie status and ask - what's the scary sharp method?!![]()
In the longer term though, the SS method of sharpening is generally reckoned to be less economical than the purchase of a diamond stone or other method of honing as you tend to go through a lot of abrasive medium, 'specially if you use the cheaper option of wet & dry paper - RobAled Dafis":1rwmhbt2 said:billw":1rwmhbt2 said:I'll show my newbie status and ask - what's the scary sharp method?!![]()
where the same results can be obtained with Scary Sharp for a lot less money.
Aled
Hi Bill,billw":gmir62e8 said:I'll show my newbie status and ask - what's the scary sharp method?!![]()
The first project should be a bench hook closely followed by a mallet and then a bench....Grinding One":1ykk94qw said:OK here`s my two cents worth,unless your very very good ,your going to need a mallet,or hammer to put the pieces together with....Tap,Tap,Tap.
Grinding One":iljb0ad6 said:OK here`s my two cents worth,unless your very very good ,your going to need a mallet,or hammer to put the pieces together with....Tap,Tap,Tap.
