Bs350 bandsaw, wheel fouling rise and fall
LarryS.
20 Nov 2007
Hi all,
Just cleaning up my Bs350 and found that the rise and fall is fouling the upper wheel, I hadn't noticed a problem with it before.
Is it safe to adjust the mechanism, if so how (there aren't any instructions in the manual)?
Sent from my SM-G903F using Tapatalk
Seems to be a common design flaw. My axminster 350 also does that. And in a previous life I had a small Fox bandsaw with exactly the same fault.
As long as it only fowls when at the top of its travel, just set it lower and ignore it.
All
All fixed ! There were two retaining bolts I found, adjusted and sorted
Sent from my iPad using Tapatalk
PaulR":3m34u7s7 said:
All
I was just about to mention the two bolts. Having removed that a few times when making changes, if you don't get it just right it will catch the blade. ................................................ another learning curve.
Malcolm
I also found it helpful to remove about 1-2" off the bottom of theat as it makes the blade easier to see when cutting.
Alex, 1 to 2 inches off the bottom of what?
That's right Mike. I found the blade guard rather long and by removing a couple of inches, it gave a far easier view of the blade when cutting.
However, depending on what you us your saw for, you may never need to do this.
Alexam
I have thought of doing this myself, but not got the right OTuit yet. (hammer)
Mike
