Vann
Hi Andy. Can you expand that a bit (I have a saw handle that needs just this repair)? Did you force the split open wider to get the glue in? What glue did you use? I've given my handle quite a few coats of linseed oil - is that likely to cause the glue to fail (did yours hold okay after you'd used Professor Andy's magic restorer fluid)?AndyT":153adjzv said:...and was then glued together where it had split
The break opening in mine isn't as wide as yours was.
Cheers, Vann.
