Bristol Locking Handles
sooty
30 Jan 2006
Nott's
Hi anyone know where I can buy some Heavy Duty 6mm Bristol locking Handles for my Perform CCL Lathe.
I get through the ones Axminster supply at a fair rate of knots (regardless how carefully I tighten them) they only seem to last a couple of months before I round them off which makes them useless
Phil
Alternatively give Axminster a ring and tell you what you need. They do some heavy duty ones which are much stronger. I had the same problem.
Thanks for your help I need a top up order from Axminster so I will give them a ring and see if they still do heavy duty ones
Phil.
That is the handle i got from Axminster to replace the ones on my Perform CCBL and they were M10.They are a much stronger handle and might need cutting down.
Axminster did send M6 out but they were too small,and this was after checking with their technical dept.
So wether they are different size threads on each machine i can't say.
Paul.J.
Thanks for your input
I have ordered a pair of M10 locking handles from Axminster just have to wait and see if they fit ok
Phil
I am after a 4mm Bristol locking lever. I have checked the above posts, not applicable. I want it for a QR for my Hegner scroll saw.
Hi,
Your covered for suppliers, the one thing I've found that has happened to the ones on my lathe is dust, will work down round the inside of the handle and in time stop them seating, I find a good clean out and they work fine, or has this only happen for me..
Regards. David...
I have not had any problem with mine. I have them on the lathe, drill, sanders and on plenty pf jigs. My technician regularly strips his, and replaces the plastic body ones with metal bodied. Still no response from Jencan, but I live in hope.
Thanks, I have the WDS info and am awaiting a reply from them. The Other link does not carry 4mm stock, but thanks again.
