DaveL
I am trying to make a box using my router lathe. The last time I posted about this I had made a 12 sided piece of ash on the lathe. So I then had to hollow out the middle, I used my Jasper jig for this:
This works quite well, I used a top bearing guided cutter to clean the centre of the box, this stopped me from cutting into the side
I then thicknessed a piece of walnut for the lid. I had to stick a bit of ply on the top to take the guide pin for the jig:
It almost worked, but the walnut split on the grain as I tried to take a final cut. :x
So I had to make a second one.
To continue on the same theme I had a tear out problem on the bottom of the box and had to make a second one as well. :roll: Anyway here is the thing before finishing.
One last thing before the finish goes on.
And here it is drying.
It will need a couple more coats of finishing oil.
Is there a class for small boxes as its not in the same league as most of the other nice bits of work posted here :shock:
