Box Mitre
I’m enjoying watching this one. Bold metalwork and bold woodwork =D>
Will there be an adjusting mechanism too?
Yes Jim, a cheap, narrow car boot Marples I think it is but I need something wider too - an excuse to buy chisels from car boot sales again as square ended scraper fodder. Hooray!
Thanks Toby. You have great faith ....
Rxh, no adjuster. It has the bridge for a wedge. More fun with Yew.
I put it together this afternoon. Nearly forgot to do something that I have only just noticed on Bill's CD - to take some off the inside of the tenons
in case peining squishes them sideways into the mouth area.
Other things to do were to open the mouth a little and to clean up the ends of the sole that will protrude past the body at either end and will be difficult to do any major scratch removal with it together. Some work is inevitable but here's hoping for as little as poss. in those corners.
And of course, file the compounds.
I did it up on the big anvil. It's so much easier to pein than a smoother or a panel ... it's flat all over, so no need for anything other than the anvil. Here is my cross pein punch spreading from the middle to the edges and filling in the compound corners:
Made sure the corners were filled and did the sides up.
Then Dreadnought work taking the waste off
and switching to a cross cut file as I start to blend in with the side - drawing the file. Just the one stray hammer mark that did disappear eventually.
More soon - the ugly part is nearly over.
Great thread / work.
Mr thicko here but I thought the joy of a two piece sole was to make the mouth gap before you join them ?
Blimey just had a look at a few antique soles on jimbodetools.com and they do indeed have very, very tight mouths.
Bevel up + v.low angle iron = Extremely tight mouth.
Can you even get a match in that mouth ?
Thank you the penny has dropped.
I'd just like to say that this all looks tremendous. Bill Carter should be proud of his pupil!
The 'offcut' of yew looked rather fine too.
Thanks Andy - I'm sure Bill will find plenty wrong with it. He told me I'd cut the pins the wrong way round before I told him which side was which ... (hammer) . More on that off cut in a bit.
I draw filed the sole today - trying to get it as flat as possible before starting to lap.
When there is a long way to go, I start to draw with a Dreadnought.
Why waste time with any other tool like a piddling little bench file or a milling machine? Only half - joking there but there is a downside to all draw filing. You can never remove as much stuff at the ends as you can in the middle. So anything short will always tend toward concavity; like oil/water stones always do with use. Fortunately the Dreadnought provides its own straight edge for checking.
To counter this I cross file the ends occasionally and then draw out the marks.
Back to that off cut and taming Yew in general - I had a go at planing the other edge:
I know it's mostly sap wood but it's still very hard and there is a knot at the end. It's all down to the choice of plane and the one I used did it perfectly .... even though it has no infill or wedge yet and I was just holding the iron in place with my fingertips...
I like mitres. You couldn't do that with a half made BD. The definition of a mitre plane could be: "Thingy to hold your paring chisel properly"
Just for Mr. P - here is the blade at full extension. Too far out of course as to have it this far forward closes the gap.
I'm loving making this. I just hope I can get the woodwork right.
Hi Richard
Have you tried the Dreadnaught on the Yew?
Its coming along very well.
Looking very impressive indeed. I can't tell the scale of this plane (sorry if I missed some dimensions) but overall length and cutter width?
Also what is the bed angle, I notice bridge at +7 so I assume wedge will be 7 degrees - is the bed around 10-12?
The comment about paring chisel holder is probably more significant than first appears - I've previously found that under 25 degrees edge on those is quite risky (esp. on proper hard woods). Just interested in final target cutting angle? And I'm assuming this will be bevel-up, no cap iron?
Sorry, questions...
I think the yew is a great choice, and pleased to see you now mark your name on these planes. For a bit of heritage why not stamp the back of iron and top of bed with matching numbers (a bit Spiers-like) and maybe hide a date somewhere too (just an 02-14 say). Give the collectors more to worry about in decades to come - just make it as hard as possible for them :lol:
Regarding the sole dovetails, aren't they effectively compound dovetails anyway, once peined - i mean they flare in both directions and the peining fills it all out?
Oh, and let us know the weight when it's all done please. That'll do for now :wink:
Fine work indeed =D>
Apologies for loss of service - computer has blown a gasket. This from phone.
Bed angle 20 degrees, iron width 2", NSWBRASAP.
Sent from my ST26i using Tapatalk
What's an ST26i Richard?
Is it an old Amiga PC!!! :mrgreen:
Awaiting NORMAL SERVICE....(boy you had me going there for a bit! :oops: )
If the PC not restored will it be FITS? :wink:
Jim
Well that was a bit of a nightmare ... two weeks computerless and no way to check the styles of other plane wedges. I've had to resort to reading books. Now we have a shiny new pooter and I am only just starting to work out how to find the photos that disappear from the camera and gurgle out of reach into unreachable chasms of Windows7.
Anyway, I'll try some update photos.
I made the wedge much too big just in case .... squinting at small photos in last year's David Stanley catalogue ... but it is now a better size since I have had the chance to look at Bill's work again.
The iron that is in it is just a slotted parallel upside down - I need to get some more tool steel and make a proper, long, snecked mitre iron.
Oh dear Richard! :shock: :shock: :shock:
That is so GORGEOUS!!! Stunning indeed!
And I love that wedge shape...sets it off a treat!
There will be a sneck on the iron...(or did I miss that bit)....set it off a treat.
I found with the yew bowsaw that the boiled linseed oil trick so loved by Bill is also wonderful if repeated for a long time...sit in front of twenty episodes of Poirot and just wipe it on lovingly while admiring your masterpiece.
You have set the standard way up there with the best of the old boys my friend....
Stand up and take a bow...Richard T --- MASTER Planemaker
Can't do infills indeed!!! :roll:
Bravo my dear friend...truly beautiful.
=D> =D> =D> =D> =D> =D>
Jimi
Thanks for finding that iron out Mr. P but no, too wide and too far. There is a chap who sells 2"ers in Scotland ( I've lost all my old bookmarks so can't check) but it's easy enough to do myself for much less dosh. I think they were £50 a pop.
I am going to do the submersion thing with raw Linseed when I can get to the shop to get enough to do it and maybe go to a Tupperware party for the relevant container.
I'm working on a smaller one and really want to try a skew. Speaking of which, has anyone ever seen or heard of a mitre badger? I was thinking about the ultimate panel raiser and a constructive use of old slotted irons .. just rambling out loud ...
