Some discussion of it by Richard Head in this vid
As you look like the only person thats used one I have to ask are the blades like a card scraper with a burr and is it possible to sharpen them?something v similar was used by French stonemasons - obv bigger and more robust - some include teeth, some just a flat scraper blade ---- 'chemin de fer' or similar - used by masons to give a final smoothing to limestone blocks etc as well plaster as descr above - common tool once
I tried one of the cheapo Chinese ones a few years back - definitely a technique to it - broke out a blade before I got the touch, but did work shaping/smoothing wood - I guess best for some woods not others
also obv need to choose the right wood to make one - need strength in both directions, not a splitting-type wood (try elm?)
the one I had was just 'straight across' - ie no burrAs you look like the only person thats used one I have to ask are the blades like a card scraper with a burr and is it possible to sharpen them?
Regards
