MikeG.
I just made myself a bow saw. I've wanted one for a while, because I've found it an almighty faff to change blades in the bandsaw just to cut a curve or two. By the time I've done that and set everything up again properly, I'd have finished the job with a bow saw. So I pulled a couple of bits of scrap pine out of my scrap bin and made this:
I have since put the same finish on the knobs as on the rest of the saw. I guess the whole thing took 3 or 4 hours, and was all made up in the workshop. No drawings or anything. I cut up a 6mm bandsaw blade , which is held by a pin through a slot in a bit of 10mm mild steel rod at each end.
The only thing is I am not sure if I have possibly made it a bit too big. It's about 380mm in blade length. How does this compare with what you guys have?
