Kittyhawk
This relates to the gas installation in my motorhome.
Basically, the gas line from the bottle and regulator to the hob/oven is about 6m long. The hob/stove is at the end of the run. About halfway along the gas line there is a tee and a branch gas pipe goes to the water boiler. This pipe would be about 2.5m long. The water boiler is new and it and it's predisessor will keep flaming out 4 - 5 times after starting, and then it will settle down and function normally. We use the water boiler as an 'on demand' appliance, only firing it up when we need hot water.
The only reason for the boiler flame outs that I can think of is that the gas flow to the hob/stove is partially evacuating the boiler line and causing air locks in it. I'm out of my depth with this gas stuff and don't know if this is even feasible. Advice appreciated.
