transatlantic
Boom!
Does anyone have one of these?
I recieved mine yesterday and am really quite impressed with the cut quality (for a single blade), and the general build quality of the tool.
Except for one rather inportant thing. The infeed table (smaller of the two) is not at all parallel with the outfeed table. If I adjust the depth such that the area of the tables on either side of the blade is co-planer, and the area on the outfeed table is in contact with a straight edge, then the far end of infeed table is about 1mm out. Hopefully the image below helps explain more. The red area showing the 1mm gap.
Now I know this is a carpentry tool, so wasn't expecting it to be perfectly parallel, but this amount of error seems odd. And judging by how perfectly flat the tables are (milled very well), it's almost as though it is intentional or something? ... but my knowledge of how planers work, makes me think these have to be perfectly parallel and that amount of error will stop the tool working? At least from the point of view of flattening a piece of timber? maybe these tools are not designed to flatten, but to simply remove/smooth material?
Can anyone compare it to theirs?
