I've recently completed a bookcase. The problems I had with it stem from the fact that the shelves are attached to the sides via wedged through tenons. The real root of the problem was that the wood is pine and I find it so difficult to work with. In this case the mortices looked more like exit wounds than carefully crafted bits of joinery. So I put the bookcase on the back burner while thinking about how to rescue the matter.
Eventually I thought I might be able to make a virtue of a vice. I marked shapes around the mortices and then used a router plane to get them to about 3 mm deep. I then glued pieces of aspen into the resulting shallow holes. The problem was that the pine had played up again and in places the junction of aspen and pine was a mess. So I got some 5 mm wide strips of mahogany (from an old boat building model kit), marked them across the joins, routed again and superglued them in. The results are just about acceptable:
And here it is "in use":
I don't quite know what the lessons are to be drawn from this (apart from the fact that pine is clearly the poor man's Wood From Hell and should be avoided) but there is a bit of decorative potential in the repair work.
