Carlpenter
I’m making a bookcase door and hoping some of you can bounce ideas with me.
It’s 1.4m high x 2m wide 320mm deep with mirrored back.
I’m working to a possible weight of 300-400kg.
Found a bottom pivot system used for gates capable of taking 500kg and thinking to make up a pin/sleeve for the top that can be fed in as I “hang” the door.
Would also like a dampener cylinder to stop the door slamming. Anyone come across such a thing that could handle this sort of weight?
Think I’ll use a magnet to hold it shut.
Considering to make it in 2 parts. A frame (easier to handle, set up and swing) and the bookcase that I will attached to the frame once installed.
Any advice/ideas/experience greatly appreciated.
