Firstly apologies that this isn't purely woodwork.
I'm intending to reinforce some large half lap joints with M12 Bolts. I have found that if the diff I drill a 7/16 hole (11.125mm) this gives a very snug Fit for an M12 thread which cuts its own thread slightly through the wood on the test hole I have drilled.
Is it a bad idea to have something so tight fitting and should I consider a slightly wider hole to allow for a little movement of the wood? The joints are going to be made to connect a 9 foot 6" x 6 Beam between two posts.
Ewan
Sent from my SM-G900F using Tapatalk
Ewan
