- Joined
- 16 Sep 2006
- Messages
- 391
- Reaction score
- 158
Me too!I have the faithful one and it's not bad tbh.
Well up to the wood butchering I want to do!!
Cheers James
Cheers James
That's good I have both and have been ok.I ordered a kit by Faithful, comprising No.4 and 60 1/2 Block plane set in nice wooden case. It arrived last night. Both of them seem good. Will be testing them out soon.
Fine in softwood not used mine much in hardwood.The Faithful plane set is working good out of the box. Quite pleased. Not sure how long the blades will hold their edges, but will see.
Tried mine on the Pine boards. The smell of the pine from the shavings was good in the room.Fine in softwood not used mine much in hardwood.
I have the Quangsheng low-angle others have mentioned. I don't think it's very high-quality. The various adjustments are very stiff.
If it's an old one it might be a #65-1/2 - same style only wider. If it had a knuckle lever cap it might be a #65
See here
You are not kidding, £174 and only comes in 0 volts, Veritas Low Angle Block Plane with PMV-11 25 Degree BladePersonally I use a Veritas low angle block plane which is superb, but pricey
