Blades for cutting MFC
Assuming you are looking at 250 diameter blade (that was the picture)
any good quality blade with 80 teeth triple chip tooth configuration will give a nice clean finish on the top of the cut.
If you have a scoring saw underneath on your machine you will also get a clean finish on the underside.
If not, when the main blade gets a little into its life you will find breakout on the underside. This can be reduced by having a sacrificial piece under the board.
I have top quality blades available £38 + post + VAT
Doug
