woodbloke
:lol: - RobPaul Chapman":dxeatz85 said:woodbloke":dxeatz85 said:...mind you, if you can pick one up second hand :wink:
You talking about me again :? :lol:
Ibig soft moose said:woodbloke said:Lots of pennies to save, but IMO Lamello jointers are worth saving for. Superbly made and very accurate, can't be beaten - Rob
true but at that price you might as well save a little longer and get a domino.
I've got a makita bj which works fine , but i also like the dewalt which we have at work.
we used to have a clarke but it was awful so we condemned it.
the only cheap one ive encountered that was any good was axminsters own but they dont make tht anymore.
Tim Nott":o91jsw40 said:The only bj I've seen that was any good was the Elu - it rocked on a pivot, rather than slid in grooves, and had a micro-adjuster to set the horizontal position of the blade.
Paul Chapman":1ivm5fm1 said:Tim Nott":1ivm5fm1 said:The only bj I've seen that was any good was the Elu - it rocked on a pivot, rather than slid in grooves, and had a micro-adjuster to set the horizontal position of the blade.
It's still available under the DeWalt brand http://www.dewalt.co.uk/powertools/prod ... no/DW685K/
It's excellent (I have the Elu version) but it lacks a continuously variable angle fence.
Cheers :wink:
Paul
Many thanks, Paul, that's the one - they don't give them away do they?Paul Chapman":prfby03w said:It's still available under the DeWalt brand http://www.dewalt.co.uk/powertools/prod ... no/DW685K/
Cheers :wink:
Paul
ivan":43b02xqq said:The Trend looks similar to the early Freud machines. This type (and other low cost jointers) does not have a finely made fence that automatically remains parallel to the blade as it is adjusted.
However, provided the blade is parallel to the case, many joints can be registered off the base without using the fence at all. When the fence is essential, it must be set using a setting block* that you make yourself. With the jointer resting on its base, on a flat surface, press the fence down on the block and then tighten up.
* cut a few blocks of different heights to suit your usual work, make them as wide as the fence, and make sure top and bottom are parallel.
