Sure, that is also an option. He might try out a secret mitre DT.Why not concentrate on basic hand skills and make a shooting board with 45 degree angle
Takes a bit of practice, though.
Not understanding the relevence. I am assuming hid mitres are long enough to insert a biscuit. The points I was making areHe might try out a secret mitre DT.
It's a kind of dovetail joint. No dowels, biscuits...Not understanding the relevence. I am assuming hid mitres are long enough to insert a biscuit. The points I was making are
- You dont have to buy lots of expensive tools like track saws
- Shooting material is a good hand skill so making a shooting board would be much cheaper than a track saw and develop a set of skills which would be applicable to lots of applications
Question, have you made any furniture before?Im looking to start making furniture in my spare time, starting with coffee table & side table.
Clearly from the range of response posts, there are lots of options, but for me I'd use a biscuit jointer to help with alignment, on the basis I've cut the mitres accurately in the first place.I will be looking to do waterfall style tables so looking to join mitres together, which is the best method to achieve this?
How will you you prep your timber to this range of sizes?Just to add, the wood will be between 20mm thick and 30mm thick on different pieces.
I have the XL 700 which now lives next to my lawn mower because I just cannot accept the issues with precision
Poor old @Brdy has probably abandoned all hope.
I've seen you post numerous times about this, You clearly have a pup, could you have not sent it back to Festool to get checked, my 500 & 700 have been faultless, in reliability, accuracy/precision, plus I stretch their designed purpose to an extreme.
If not already in your arsenal, a track saw is an inexpensive and surprisingly useful too. Despite having a reasonably sized bench saw which I can rip full sheets down in, it's more convenient sometimes to use the track-saw and it's very accurate and quick. The other tool I have which I bought for one job and thought I'd rarely use has also proved very useful and that's a Spotnails Maestri SE30-08 bradnailer. I have a compact workshop and with he dust extraction, saw, router table and assembly benches I have little spare room for a large compressor hence bought this electric corded nailer. Very precise, reliable and useful when panel pinning for gluing up. If not already on your list, a 1/4 inch combination router is also invaluable (plunge and fixed bases).I'm still reading the many kind replies and getting slightly overwhelmed lol.
I have not made furniture before, but went to college about 15 years ago and did different projects over 2 years in woodwork, end project was to make a sash window.
I have yet to buy many tools so this post was mainly about which kind of direction to start my tool collection.
I intended to buy a band saw, planer thicknesser combo and a joining tool. I have the usual DIY tools already such as impact driver and drill, mitre saw (old hand me down), circular saw.
Any further direction would be appreciated.
A good set of quality chisels, a tennon saw, 2 bench planes, a set of marking out tools and a course and fine sharpening stone. Probably buy good quality second hand for well under £200I have yet to buy many tools so this post was mainly about which kind of direction to start my tool collection.
Thanks. It’s aimed squarely at 90° carcass joints so not easily adapted for bevel cuts, and also requires a router, and some experience to get the best from it. For bevels something like the Peanut 2 mini jig and connectors work well but again requires a fairly beefy router.What about Peter Millard's new loose tenon jig? I've not tried it but looks like it could be a winner... Cheaper than Domino and achieves similar result?
I've filed a couple of blades for rip cuts with my jigsaw, and they work an absolute treat! They cut straight, and so fast!Great on the crosscut, but no jigsaw performs on rip. Which is why so many manufacturers advertisement vids show cross cutting only.
Might CC 145mm, but I'll wager a 45mm rip would have it wobbling all over the place![]()
A glue ready joint cut?I've filed a couple of blades for rip cuts with my jigsaw, and they work an absolute treat! They cut straight, and so fast!
No! An un-reinforced mitre will not properly accommodate humidity-change related wood movement.Even if you are glueing up solid wood mitres, you do not need reinforcing.
No! Although they are at 45deg, they are equivalent to an end-grain joint. Your comment about 'sizing' in effect admits this.Mitres are close on long grain. They are not end grain.
