BIG Savings on Veritas
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
BIG Savings on Veritas​
Limited time only: Grab up to 35% off Veritas products before it's too late! While stocks last.​
Our top recommendations​
Veritas Bevel-Up Jointer Plane with PMV-11 Blade​
The largest member of the Veritas bevel-up bench planes
Ideal for jointing edges and flattening large panels
57mm (2.1/4") wide 25° lapped blade, adjustable throat plate​
Now £349.96
Was £467.48​
Veritas No 4 Smoothing Plane with PMV-11 Blade​
Most commonly used bench plane
Ideal size for general smoothing, finish work
At 2kg, it has enough mass to cut smoothly but without fatigue​
Now £259.96
Was £324.48​
Veritas Steel Straight Edge 24"​
Ground flat to within 0.025mm on both edges
Stress-relieved, remains true under temp. change
Stands on edge unsupported, so hands free for precise measurement​
Now £67.96
Was £77.48​
Veritas Wheel Marking Gauge Standard - Non Graduated​
Hardened steel wheel cutter
Cuts wood fibres, rather than tears
Marks cleanly, even on cross grain
Wheel retracts into the face of the gauge for storage and protection​
Now £28.96
Was £34.48​
You may also like…​
Veritas Journeyman's Brass Mallet​
Now £39.95
Was £49.48​
Veritas Precision Square (Metric)​
Now £46.96
Was £54.98​
Veritas Spokeshave Concave Base​
Now £115.96
Was £137.88​
Veritas Crosscut Dovetail Saw - 16 tpi​
Now £76.96
Was £92.58​
Veritas Miniature Shoulder Plane​
Now £49.96
Was £54.48​
Veritas detail Flush Cutting Saw - 26 tpi​
Now £25.96
Was £29.98​
