Osvaldd":146oin0h said:
Im having issues with my no 220 block plane blade constantly chipping. At 25° its almost unusable, it would chip immediately. Secondary bevel at 30° helped but did not eliminate the issue.
I don't know if its the actual blade(its old, possibly 50s Record) at fault or is it common with BU planes? It drives me mad.
Hi Osvaldd
This is not about BU blades, but about your blade, per se. It is too soft to hold an edge.
25 degrees on a BU plane (with the 20 degree bed of the #220) is actually potentially more durable than 30 degrees on a BD Stanley #4 (with a 45 degree bed). Both have a cutting angle of 45 degrees, but the BU plane widely outlasts the BD plane in my experience (and testing).
Let's face it, the #220 is not the most expensive block plane around, and the quality of the blade is in line with this. Replace it or, better still, get a better plane, such as a vintage Stanley/Record #60 1/2. Or a more modern block plane.
If finance is an issue, I would re-heat treat the blade. This is pretty straight forward. Yell out if you want to go down this path.
Regards from Perth
Derek
