thetyreman
Nobody has mentioned plane socks?
I've heard you can put it in just a regular sock, must admit I keep one of mine in one because it's rare I use it and it seems to stop all the rust.
in use I always rest my plane sole down in shavings I thought it was just me, when it’s finished with its back on the shelf behind the bench as I described aboveOn the bench does no one else get shavings to rest the plane on?
They might also have fluffy babies....If you're feeling flash you can store them in an egg incubator, the heat keeps the rust at bay and they get turned automatically so you don't need to worry
Or verrucas if it's unwashed socksThey might also have fluffy babies....
Thank God Doug. For a moment there I thought I was a maniac.in use I always rest my plane sole down in shavings I thought it was just me, when it’s finished with its back on the shelf behind the bench as I described above
I made one of those a few years ago and I must admit it's very useful.I'm making one of these this week as it's a good, simple idea. I will fill mine with camellia oil
How to make a Rag-in-a-can Oiler | Paul Sellers - YouTube
and notice that he doesn't put his plane on its side!
Phil, Do you have any references for this, or where you heard it? I've worked in R&D manufacturing and engineering for a while and not heard of this effect. I'm sure the observations are real, but the explanation seems a bit odd, I'd be very interested to follow this up. Thanks TomAll good advice about keeping planes on their sides; it is what I was taught at school. But, and it is a big but: they need turning every week. Why? Well the sharpening process induces minute molecular level electrical / magnetic charges in the blade which concentrate around the cutting edge.
The affordable ones tend to be. Buying second hand tools has become v expensive recently, lockdown and the excellent blogs of Paul Sellers et al have re-kindled the hobby and value of good tools so people are digging out their attics, draining ponds, excavating gardens and selling off their forebears air-looms .Most of the old tools I buy seem to have been kept in a pond. Is this normal?
It's weird to see assertions like this - not that it's wrong in his area. He's probably relaying what he saw.
what's weird to you is common sense to me, it makes a lot of sense, less danger, it stops the lateral adjustment leaver from loosing its setting and it protects the blade as well, I'll continue not putting it on its side until the day I die.![]()
