iNewbie
JonnyW":201j3ckv said:It's getting a HSS bit big enough for the end of the Trend T11 key.
Jonny
Any local engineering shop would likely drill out a hole for a drink.
Jonny
JonnyW":3hxhafjd said:Going under the table to press the spindle lock during bit changing isn't a problem and wouldn't bother me. What is a no brainer is the ability to fine tune bit heights without constantly going under the table. That's why I liked the UJK raiser - very very accurate. And that's why I bought their fine adjuster for the fence. It's the fine tuning of the bit to the work piece I would like to do above the table.
Wizard9999":3jdj02qx said:MikeJhn":3jdj02qx said:Just to make it absolutly clear the Triton does not switch off and on when you lower or raise it either, you have to do it manually and only then does the spindle lock operate, you must switch the router off and close the switch cover then raise the router to lock the spindle, then you have to open the switch cover to release the spindal lock to allow it to be lowered only then can you switch the router back on, that is three times you have to access the router under the table to change a bit.
Mike
Struggling with your maths here. Switch off and close cover, raise collet and make changes, open cover and switch on, lower collet. If it is connected to an NVR (and I guess ideally unplugged as well) why do you need to only switch on as a third step?
As others have said, it really isn't that hard to just reach under the table, once you have done it a few times you don't actually need to look at what you are doing. You're happy to have spent money on a router lift and use it to save you having to reach under the table, that's your choice and it works for you but come on don't over egg the pudding and try and make out it is a more of a hassle than it actually is.
Terry.
MikeJhn":3ufjgiej said:Wizard9999":3ufjgiej said:MikeJhn":3ufjgiej said:Just to make it absolutly clear the Triton does not switch off and on when you lower or raise it either, you have to do it manually and only then does the spindle lock operate, you must switch the router off and close the switch cover then raise the router to lock the spindle, then you have to open the switch cover to release the spindal lock to allow it to be lowered only then can you switch the router back on, that is three times you have to access the router under the table to change a bit.
Mike
Terry.
Terry you have to open and close the switch cover on the Triton router to lock the spindle, there is no other way as far as I remember its automatic when you raise the router except for the cover interlock.
Mike
If you (and Peter) don't mind I'd be interested in hearing what Peter has to say. Always good to hear an independent point of view and Peter is very good at this, even when he owns something he manages to avoid the trap of just trying to justify his own decisions / purchases which others sometimes seem to fall into.JonnyW":fipp6z8u said:Peter at his New Brit Workshop youtube site, gives an excellent review of the UJK setup.
I've also contacted him. He uses the Dewalt 625 with an Axcaliber collet extension. He also uses the UJK router raiser.
I understand that the setup of the collet extender means you can raise it above the table and use two spanners to change bits. So there's no need to go under the table with this setup?
Jonny
Wizard9999":q469q7rl said:As others have said, it really isn't that hard to just reach under the table, once you have done it a few times you don't actually need to look at what you are doing. You're happy to have spent money on a router lift and use it to save you having to reach under the table, that's your choice and it works for you but come on don't over egg the pudding and try and make out it is a more of a hassle than it actually is.
MikeJhn":3ecnjc6j said:Well Johnny you certainly started something with this thread, there has been plenty of post concerning the inconvenience of using a Triton Router on the various thread on this Forum, but I seen to be only one prepared to post his observations on this thread, it seems much to the detriment of my voracity. (hammer) :roll: Its only when you start to use something like the UJK engineered above table lift that you realise how inconvenient some other can be, but I am sure you will make up your own mind in the end. :wink:
Mike
